Virtual Memory leaking when not in use
Xyon
Post by Xyon »
Hi support team
I have a weird issue when Altap Salamander (AS) is running on a remote desktop console:
Scenario is:
I have AS 3.06x64 installed on a server PC. I connect to that server using Windows Remote Desktop and run AS. I then disconnect from that server, leaving my session running.
On this server I also have a remote management & monitoring (RMM) software installed. After a few hours of having disconnected, the RMM reports back to me that AS is using large amounts of physical memory, eg 4GB (out of total of 10GB on this server). The strange thing is that if I re-connect to my remote server session, the memory use of AS immediately drops back to a normal level (eg about 20MB).
Is there a way I can turn on some debugging mechanism in AS that would assist with tracking this, eg have AS write a log file ?
Thanks
Felix
Graph illustrating the issue, the physical is obviously reached the max but the virtual memory is still growing...
2015-04-13 10_48_40-ALPHA_ Memory.jpg (54.68 KiB) Viewed 10576 times
Nice graph from a few months ago. Here we can see the effect of logging back on releasing all the memory.
2015-04-13 10_51_49-ALPHA_ Memory.jpg (20.94 KiB) Viewed 10576 times
Re: Virtual Memory leaking when not in use
You can download the Salamander SDK and run the tracing build of Salamander with a trace server.
