I have a registerd version Salamander 2.52 in one folder and I have Salamander 2.53 (beta 1) in another folder.
When I installed 2.53 I was asked if I wanted to use the configurations from 2.52. I said yes and it copied my set-up across.
I have since made an extensive "user menu" on 2.53.
Can I copy the configutation from 2.53 to 2.52? If so how?
Thanks - Tony
Duplicating Configuration
If you know you're going to lose - lose quickly!
Re: Duplicating Configuration
Hi Tony, backup your registry key (using Altap Salamander Registry plugin)
reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.52\User Menu
and overwrite it with
reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53 beta 1\User Menu
Do it with AS 2.53 beta 1 so 2.52 configuration is not overwritten on AS exit.
Hi Jan,
Can you guide me through the procedure to overwrite;
with
using AS 2.53 as I haven't done this kind of thing before
Thanks - Tony
Johannesburg - South Africa
with
Thanks - Tony
jadag wrote:Can you guide me through the procedure to overwrite; reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.52\User Menu with reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53 beta 1\User Menu
- Make sure no instances of AS are running and start AS 2.53b1.
- Copy this path into the clipboard: reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.52\User Menu
- Go to the left panel in AS and press Ctrl+V. The left panel should now show some folders named 1, 2, 3 and so on.
- Copy the other path into the clipboard: reg:\HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53 beta 1\User Menu
- Go to the right panel in AS and press Ctrl+V. The right panel should now again show folders with similar names, but there should be more of them than in the left panel.
- Select all folders in the LEFT panel and delete them (don't try to delete (Default), it can't be done).
- Select all folders in the RIGHT panel and copy them to the LEFT panel.
- Close AS, start a new instance of AS 2.52.
- Enjoy.
- user-menus-in-registry.png (45.98 KiB) Viewed 25098 times
Drag and drop between sections of the registry using Salamander???
Wow. Silly me, I had no idea. Very cool!
Mouse-centric, Registered
1 - Export the ALtap registry you want to duplicate by selecting Options | Export Configuration
2 - Using a good text editor like Notepad2, edit the configuration registry file you just exported from Altap Salamander.
Replace - HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.52\
With - HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.53 beta 1\
3 - Save the file and double click on the reg file. You should now have another registry entry
Thanks Ether
All I can say is "Brilliant!!" ... and it was so easy!
Thanks to all who gave advice. Hope to see you all here in South Africa for the World Soccer Cup!!!
Regards - Tony+
Regards - Tony+
