Hello,
I don't know where SS writes its configuration, history, hot paths, hot-keys etc. But maybe it would be usefull to allow user to specify a configuration file (e.g. an .ini file) which would be portable between more computers, and save all mentioned stuff in it. The same way is used e.g. by TC. You would not be forced to create/update settings when coming to another computer.
Thanks.
LuP
Configuration to a file
See the Remarks section:
http://www.altap.cz/salam_en/help/salam ... ration.htm
Also Roadmap:
http://www.altap.cz/salam_en/newver.html
"Option to store settings in a file instead of Registry."
Also Roadmap:
