Configuration to a file
LuP
Post by LuP »
Hello,
I don't know where SS writes its configuration, history, hot paths, hot-keys etc. But maybe it would be usefull to allow user to specify a configuration file (e.g. an .ini file) which would be portable between more computers, and save all mentioned stuff in it. The same way is used e.g. by TC. You would not be forced to create/update settings when coming to another computer.
Thanks.
LuP
See the Remarks section:
http://www.altap.cz/salam_en/help/salam ... ration.htm
Also Roadmap:
http://www.altap.cz/salam_en/newver.html
"Option to store settings in a file instead of Registry."
LuP
Post by LuP »
... OK, thanks, that's good.
- Will SS save configuration [also] to the specified file when launched with "-C" switch, rather than to save it to the registry?
- - If not, wouldn't it be usefull?
LuP
Man, learn to spell 'useful' when you use the word that much.
LuP
Post by LuP »
(Thanks for your "spelling check" ;-) )
