Mobile Device / Apple iPhone
df7hi
Post by df7hi »
Hello Salamander team,
we need to access the file system of our iPhones with the Mobile Device plugin.
There some is stuff for the Total Commander, but we are Salamander fans and don't want to use TC).
Is there a way to implement the underlying transport service / API into the Mobile Device plugin ?
Best regards
Thomas Illies
cincura.net
Re: Mobile Device / Apple iPhone
Post by cincura.net »
Mobile Device is using ActiveSync API. So proposed support for iPhone isn't good. Maybe somebody will use SDK and create separate plugin.
Jiri {x2} Cincura
Thomas, did you try manison's TC proxy plugin?
http://forum.altap.cz/viewtopic.php?t=2166
Zero3K
Post by Zero3K »
I just tried it. It works (except that it doesn't have the same Copy functionality as what you would normally get when copying files).
