In this preview version just listing path in a panel and view (F3) functions are implemented, thus suitable for plugins like Task Manager, Device Manager, Event Log and similar only.
Use the plugin at your own risk – Salamander may become unstable, it may exhaust system resources or explode your computer
Installation:
- Create subdirectory with a suitable name under the Salamander plugins directory
- Copy the tcfs.spl plugin to that subdirectory
- Copy a Total Commander filesystem plugin (*.wfx) of your choice to that subdirectory
- Go to Salamander Plugins > Plugins Manager and Add the Total Commander File System Proxy to the list of the plugins
- Go to Alt-F1/F2 menu and select the new filesystem
You may install as many plugins at different subdirectories as you want.
Download Total Commander File System Proxy Plugin from the project page.
