Change Directory Error(2)
ksworks
Post by ksworks »
I got 'Change Directory Error: (2) No such file or directory"
in case of directory traversing.
1) Current dirname contain '\\' code(backslash).
2) Move to parent directory.
3) *ERROR OCCURS*
Perhaps... in Japanese, we use multibyte characters
contains '\\' code in NON SEPARATOR CHARACTER.
this is error image (In Japanese).
ksworks
I guess
Post by ksworks »
In 'Move to parent' case, Slamander search-backward to '\\' code.
and remove '\\', and set directory to removed path...
so, I wrote a sample code.
one of this (test1) is a problem,
and another (test2) is NO problem.
May you review my code?
And I hope you to correct the problem.
Regards.
dirs.zip
Sample code
(727 Bytes) Downloaded 545 times
The problem is in Unicode encoding. It is not supported in Altap Salamander 2.5. We plan it for version 3.0.
