I got 'Change Directory Error: (2) No such file or directory"
in case of directory traversing.
1) Current dirname contain '\\' code(backslash).
2) Move to parent directory.
3) *ERROR OCCURS*
Perhaps... in Japanese, we use multibyte characters
contains '\\' code in NON SEPARATOR CHARACTER.
Change Directory Error(2)
- this is error image (In Japanese).
- dirs.jpg (66.17 KiB) Viewed 9545 times
I guess
In 'Move to parent' case, Slamander search-backward to '\\' code.
and remove '\\', and set directory to removed path...
so, I wrote a sample code.
one of this (test1) is a problem,
and another (test2) is NO problem.
May you review my code?
And I hope you to correct the problem.
Regards.
Regards.
- dirs.zip
- Sample code
- (727 Bytes) Downloaded 544 times
The problem is in Unicode encoding. It is not supported in Altap Salamander 2.5. We plan it for version 3.0.
