Thank you for your feedback and reports! We are trying to fix all problems and release another EAP version ASAP.
x64 Stress Test Mode
In the x64 version of AS 3.0 PB75 we introduced "Stress Test" mode. You can notice "ST" in the Altap Salamander 3.0 x64 title bar. During the AS start-up process we are reserving lower 4GB of memory, so all further memory allocations are placed above 4GB limit. The Stress Test is GREAT for EAP stage of Altap Salamander because it helps us locate bugs in Salamander and plugins. Unfortunately there are faulty x64 shell extensions (third party DLLs installed on your computer) that work just in the lower 4GB memory region (0x00000000????????). Such shell extension will crash Altap Salamander running in the Stress Test mode. It can crash during AS start-up, during opening the context menu, or while opening file from the panel. It will easily crash other memory hungry x64 applications such as Photoshop, rendering software, etc. We should identify such shell extensions and ask their developers for fixes.
For the shell extension authors we attached a sample application including source code (see testctxmenu_x64.7z). Run Release\testctxmenu.exe and choose Exhaust 32b address space command. Then right click the window background to open context menu for C:\Windows\win.ini (see WM_RBUTTONDOWN / DoExplorerMenu() function call)
Known Faulty x64 Shell Extensions
* Beyond Compare 3, version: 3.3.4, build 14431, released Feb. 24, 2012 - Crashing while opening Altap Salamander context menu. See http://forum.altap.cz/viewtopic.php?t=5474
* Actual Multiple Monitors 4.0 - released March 13, 2012 - Crashing while opening Altap Salamander context menu. See http://forum.altap.cz/viewtopic.php?f=24&t=5476
Already Fixed
* Old version of Avast\snxhk64.dll (6.0.1367) - Please upgrade to latest fixed version of avast! version 7.
Known Problems in AS 3.0 beta 1 PB75
Slower copy over XP 100Mb network http://forum.altap.cz/viewtopic.php?t=5493
False positive antivirus warnings http://forum.altap.cz/viewtopic.php?t=5477
(FIXED) Dropbox icons problem http://forum.altap.cz/viewtopic.php?t=5485
(FIXED) RAR 4.* problem http://forum.altap.cz/viewtopic.php?t=5487
(FIXED) Help > Task List > Break command doesn't work on Windows XP x86. Bug report is generated but the Bug Reporter is not started until next start of AS.
(FIXED) Invalid speed displayed for network copy operations http://forum.altap.cz/viewtopic.php?t=5492
(FIXED) Crash while opening some UDF ISO files.
(FIXED) Small text box area during Installer/Welcome screen. See http://forum.altap.cz/viewtopic.php?t=5473
(FIXED) Image Viewers related freezing on Windows XP SP3 x86. http://forum.altap.cz/viewtopic.php?t=5468 http://forum.altap.cz/viewtopic.php?t=5469 http://forum.altap.cz/viewtopic.php?t=5478
(FIXED) Crash while moving file into the ZIP archive opened in the second panel.
(FIXED) Crashing when opening password protected RAR files with encrypted filenames. http://forum.altap.cz/viewtopic.php?t=5472
(FAULTY SHELL EXTENSION) Crashing on Win8 x64 context menu. http://forum.altap.cz/viewtopic.php?t=5474
(FAULTY SHELL EXTENSION) Crashing in ammemb64.dll (Win7 x64). http://forum.altap.cz/viewtopic.php?t=5476
(SANDBOXIE BUG) Doesn't work sandboxed (Sandboxie) http://forum.altap.cz/viewtopic.php?t=5479
PB75 - Known Problems & Stress Test Mode
Forum rules
- testctxmenu_x64.7z
- (26.58 KiB) Downloaded 1111 times
