PB75 x86: UI freezes on F3 w/image file
Forum rules
JohnFredC
Post by JohnFredC »
To reproduce:
  • 1. Navigate to a folder with images.
    2. Select any image file (jpg, png, etc.)
    3. Press F3
    4. Cursor flashes the hourglass (watch closely!)
    5. Salamander UI freezes, cannot close with window controls.
Mouse-centric, Registered
Re: PB75 x86: UI freezes on F3 w/image file
Do you use Windows XP x86 SP3?
JohnFredC
Post by JohnFredC »
Sorry, I should have specified my system. :(
Yes, XP SP3
Fixed
Simple fix, like a small file we can download, or do we have to wait for the next PB?
(As it is, it's annoying in all respects. x86, where Pictview "works", but not on XP, & x64 where Pictview doesn't yet work. Ah well, that's what PB's are for :-).)
(I have to laugh. When it's there & you're used to using it, even knowing that the bug exists, & that it is going to kill your session, you still hit F3, as a matter of course, only to lock up. Now I have think, hey, don't hit F3! :lol:.)
We must release a new EAP build, this bug was spread across the whole code base.
I'm working on the last fix before we can release next EAP (The Help > Task List > Break command doesn't work on Windows XP SP3 x86).
But don't worry, we are working over weekends and holidays ;-)
