AS 3.0 (PB75 x86) - Malware warning (AVIRA)
Forum rules
AVIRA Antivir Personal reports a trojan horse TR.ATRAPS.Gen in the download file as30b1pb75x86.exe and in uninstpl.exe on install.
(Just so you know)
Re: AS 3.0 (PB75 x86) - Malware warning (AVIRA)
It is a bug in AVIRA. Please contact AVIRA support or consider another antivirus.
Thank you for the info :)
ku
Post by ku »
SImilar message in salbreak.exe with the f-secure antivirus during install. Installation is not possible without antivirus switched off.
Regards
Ivan
Could you please show us the f-secure antivirus message? Is it "TR.ATRAPS.Gen" again?
Latest ESET NOD32 Antivirus and free Microsoft Security Essentials work fine. No false positives issues.
ku
Post by ku »
Antivirus message
Antivirus message
Jan Rysavy wrote:Could you please show us the f-secure antivirus message? Is it "TR.ATRAPS.Gen" again?
It is "Trojan.Peed.Gen".
Ivan
Yes, "Trojan.Peed.Gen".
VirusTotal: salbreak.exe
I found False Positive web page for F-Secure: http://www.f-secure.com/v-descs/other_w ... tive.shtml
Please submit the salbreak.exe to the mentioned Sample Analysis System (SAS).
False Positive reporting for Avira: http://analysis.avira.com/samples/index.php
ku
Post by ku »
Jan Rysavy wrote:I found False Positive web page for F-Secure: http://www.f-secure.com/v-descs/other_w ... tive.shtml
I did it. Hopefully they repair it. If you check salbreak.exe wtih virustotal, you will see that 5 out of 40 antivirus detects this program as malware. In my experience even if you submit this problem to all of this antivirus companies, this problem will periodically return.
virustotal results - https://www.virustotal.com/file/37c2c29 ... 334044039/
Best Regards
Ivan
Thank you! We didn't know about virustotal, it looks great.
Jan Rysavy wrote:Thank you! We didn't know about virustotal, it looks great.
Then you might also add http://virusscan.jotti.org/en to your bookmarks...
