Total Commander Proxy Plugin
Thanks for this plugin.
I use it with the TC Canon camera plugin (Powershot A95).
Copy time for 24 files of 50.538.267 bytes total is 1:50, approx. 459 kB/s. Not too bad for a real-life USB 1.1 connection. The 'Microsoft Scanner and Camera Wizard' is faster (1:30, both in advanced user's mode and in standard mode) but I love the system integration of my camera that your plugin provides.
For copying lots of files I use a cardreader anyway.
This plugin is really good idea! I tested it with NokiaFS plugin and implemented functions works fine. (Only cancelling is problem here too.) I hope, you will add copy/move to other direction and delete functions soon.
Thanks for developing this plugin!
Thanks for the feedback. I have fixed the copy/move cancellation problem for the next version of the plugin. I'm implementing transfers from local filesystem to plugin, unfortunately I have less free time than I would like to have, so development goes slower than expected.Croog wrote:This plugin is really good idea! I tested it with NokiaFS plugin and implemented functions works fine. (Only cancelling is problem here too.) I hope, you will add copy/move to other direction and delete functions soon.
error
Plugin dont work I add plugin in "Plugin Manager" and after I see following errors
- error1
- ss-tc1.PNG (6.56 KiB) Viewed 79891 times
- error2
- ss-tc2.PNG (9.55 KiB) Viewed 79892 times
rajce.net | místo pro vaše fotografie
Re: error
This error is reported when proxy fails to initialize the Total Commander plugin. Are you sure you have any TC plugin copied into the same directory where the proxy (tcfs.spl) is located? Does it have the WFX extension? If so, what TC plugin is it?cubas wrote:Plugin dont work I add plugin in "Plugin Manager" and after I see following errors
Re: hi
Is this a bug report or a feature request, 'cause you know, I can't tell. At least, you could tell us, what TC FS plugin you want to use.sergo wrote:copy and e.t.c. operation not working ):
Total Commander CD/DVD Burning Plugin only works with TotalCMD, not with EFCommander, SpeedCommander, ...sergo wrote:this is not bug report.
use NetworkAlt, NeroPanel, CD/DVD Burner - all not work soceful
(my bad english (: )
Read the license.
"This software is a plugin for the file manager Total Commander by Christian Ghisler and may only be used within that file manager. Its functions may not be called from any other application, and it may not be incorporated in any other software package. Use in any other file manager that supports the Total Commander plugin interface is only allowed with express permission of the developer."
