Good morning,
I really didn't notice this until last week, but I have the feeling that something changed with version 3.06 (64 and 32 bit)
I frequently copy files from one folder to another using F5 or after usign Ctrl+F10 (comparing files and (sub)folders) from one panel to the other.
What I notices that after the copying is finished, the focus is no longer on SS and that I have to click the application window to continue.
To make user I was not mistaken, I used tested it on my other PC where I still run version 2.54 and that does not happen there.
I compared the Configuration settings but cannot find a reason
Both Systems run W7.
Any idea why this happens?
Regards,
Hans
Version 3.06 focus lost
Hans
"IT" Always crosses your path...
Hans
