Empty file list when working with GoDaddy's FTP servers
roman2
Post by roman2 »
Empty in Salamander, but filled with content in FileZilla. What can I provide you with to help you fix this?
Using Salamader 3.06 (x84)
Re: Empty file list when working with GoDaddy's FTP servers
If this is public FTP, please send me URL, I will try to reproduce it.
If not, login and right click panel and choose Show Raw Listing from context menu, then Save As and send me that listing to forum or email petr.solin@altap.cz (if it contains sensitive data).
roman2
Post by roman2 »
The Raw Listing was empty. However, upon logging in, I got an error message, which I will attach here. At the end, it recommended that I try passive mode. Switching to it has resulted in successful interaction with that FTP server. I didn't have to do that in FileZilla, though — it just worked. I'd like Salamander to just work too.
That's not a public FTP server.
Salamander - GoDaddy FTP.jpg (27.18 KiB) Viewed 45016 times
Yes, it can be better. Thanks for idea!
KNUT
Post by KNUT »
roman2 wrote:Empty in Salamander, but filled with content in FileZilla. What can I provide you with to help you fix this? Using Salamader 3.06 (x84)
Same problem here! Is there a fix in 3.07?
Kind regards, KNUT
And have you tried to switch to passive mode as recommended in error message?
KNUT
Post by KNUT »
Petr Solin wrote:And have you tried to switch to passive mode as recommended in error message?
Yes, that solves the problem. But it is inconvenient. Any news for the upcoming version 3.07?
Kind regards, KNUT
No change in this respect, sorry.
