"The Target can not handle this type of document"
Windows XP, SP2.
Right click a file in Servant Salamander panel, choose the Send To > My Documents command.
File is successfully copied but error message appears: The Target can not handle this type of document.
Windows Explorer works fine.
http://support.microsoft.com/?scid=kb%3Ben-us%3B328856
Could you reproduce this problem?
-=Majkl=-
Post by -=Majkl=- »
reproducible, even in totalcmd :)
explorer works fine too
I can reproduce this problem with Windows XP SP2. Start for example Windows Notepad, from menu Files choose the Open command, right click some displayed file and choose the Send To > My Documents command.
More about this Windows XP (still unfixed) problem: http://groups.google.com/groups?q=%22Th ... ocument%22
