Page 1 of 2
Lose FTP-Connection after hours
Posted: 14 May 2015, 12:29
by stefanstp
My OS is Windows 8.1 and a have never problems with ftp. But since 1 week i get after hours this message:
Error: (10093) Either the application has not called WSAStartup or WSAStartup failed
What can i do? I have only the windows firewall and anti virus program.
Re: Lose FTP-Connection after hours
Posted: 14 May 2015, 13:17
by Petr Solin
We are calling WSAStartup (and result is checked) when FTP Client plugin is loading, so error message is probably without sense. We don't have any idea what can cause such problem, we are sorry.
When you close and open again Salamander, does FTP plugin work again or not?
Posted: 14 May 2015, 13:31
by stefanstp
After a restart from Salamander all works fine.
Posted: 14 May 2015, 13:37
by Petr Solin
OK, please try just to unload FTP plugin if it helps or not. When this FTP problem occurs: go to menu Plugins / Plugins Manager, locate FTP Client plugin, click Unload button, then close dialog and try to use FTP again, it will be loaded again and it will try to initialize WSA again. Thanks for testing!
Posted: 17 May 2015, 00:21
This could mean that something is wrong with your netwok configuration. Some sysytem files may have broken.
Start CMD as a administrator (WinKey+x) and scan for corrupted system files by using sfc /scannow
Check the generated report for errors and report back please.
You might also update your network drivers. (NIC, WiFi)
Posted: 22 May 2015, 10:46
by stefanstp
I get this message:
C:\Windows\system32>sfc /scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection found corrupt files but was unable to fix some
of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
supported in offline servicing scenarios.
The Log-File is very full with error-message, for example:
2015-05-21 22:31:20, Info CSI 0000076d [DIRSD OWNER WARNING] Directory [ml:520{260},l:38{19}]"\??\C:\Windows\ADFS" is not owned but specifies SDDL in component Microsoft.IdentityServer.Web.Resources, pA = PROCESSOR_ARCHITECTURE_MSIL (8), Culture = [l:10{5}]"zh-HK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
I have now update my driver for the Intel(R) Ethernet Connection I217-V. I hope this works.
Posted: 22 May 2015, 11:52
You seem to have Active Directory Federation Services installed and The permissions are not set correctly.
But I dont think thatt his would be the casue for the error mentioned.
If the new driver does not work, you can reset the winsock by following
these instructions.
Posted: 27 May 2015, 14:15
by stefanstp
netsh winsock reset
hasn't solved the problem. any other ideas?
Posted: 27 May 2015, 14:33
Try to create a new administrative account and test it with it.
Posted: 03 Jun 2015, 16:48
by stefanstp
SelfMan wrote:Try to create a new administrative account and test it with it.
Posted: 03 Jun 2015, 17:58
Can you verify the network functionality by using a different FTP client? (i.e. FileZilla)
Posted: 04 Jun 2015, 15:18
by stefanstp
I use flashfxp, this program works fine (even full upload is possible on a 100 mbit-download line => 10 mbyte per second; with salamander only 1,5 mbyte
my hope is that in windows 10 the program works well.
Posted: 05 Jun 2015, 18:21
Please can you check that you have all
VC++ runtimes up to date?
Posted: 08 Jun 2015, 10:23
by stefanstp
I have following updates installed:
It's ok?
Posted: 08 Jun 2015, 11:03
Salamander loads different libraries from v8.x,9.x, and 11.x branch. What I cant see is is the 8.x version.
On my OS, Salamander also loads msvcr80.dll v8.0.50727.6195. Although I am not sure if this is related to the problem or not.
Did you try the 32 bit version of Salamander?
BTW go to
http://www.ma-config.com/ and scan your system. You will be offered a list of updated drivers which you can download there and install.
