Hot to recover accidentally deleted files
TacticalManual
Post by TacticalManual »
i know this might sound retarded, i accidentally deleted (shift+del) my 80+ gig folder of music i use to mix on my laptop. i deleted the wrong folder by accident, and i dont know how to work this program. can someone please help. :(
1. Install Servant Salamander 2.5 RC1 to another disk (or preferably to another computer)
2. Run it (you can run Servant Salamander from another computer using your network)
3. From menu Plugins > Undelete choose the Recover Deleted Files and Directories command
4. Choose the partition
5. Find deleted files and directories
6. Use the Copy command (F5) to copy files to another disk
:!: Never try to modify (or write to) disk where the deleted files and directories have been found.
If it is the system disk, you can use the Bart's CD boot disk or remove hard disk and connect it to another computer.
Then you can safely continue in the rescue procedure.
