I've created 10 hot paths (CTRL+1 to CTRL+0). They work perfectly under normal use. But when I try to use the CTRL+Number in the Copy or Move windows, they are all shifted up 1 number.
CTRL+1 becomes CTRL+0
CTRL+2 becomes CTRL+1
CTRL+3 becomes CTRL+2
CTRL+4 becomes CTRL+3
CTRL+5 becomes CTRL+4
CTRL+6 becomes CTRL+5
CTRL+7 becomes CTRL+6
CTRL+8 becomes CTRL+7
CTRL+9 becomes CTRL+8
CTRL+0 becomes CTRL+9
Again, this only happens in the Copy or Move windows.
I'm using v3.02 (x64)
						Bug: Problem with CTRL+Number Keys In Copy/Move Windows
Re: Bug: Problem with CTRL+Number Keys In Copy/Move Windows
Thank you, this problem will be fixed in next AS version.
Still not fixed in 3.03
I'm sorry, it will be fixed in Altap Salamander 3.04.
