registry Editor Plugin's external Editor
How do I need to set up the registry Plugin to be able to properly modify e.g. a MULTI_SZ value?
Is it possible at all to have an external Registry Editor to open up to the key?
At the moment I get a temporary file, which I can modify. However, since this file is in a binary format, containing unicode data without a BOM and even containing nul-characters, I need to edit that file with a hex editor.
I don't think this is a satisfying solution.
This thread seems to suggest that it is possible to use a real registry editor. But how do I need to configure it?
Lukas Cerman
Post by Lukas Cerman »
Yes, this is not satisfactory sollution. Unfortunatelly, there is no other solution than editing the file in HEX editor.
