AS crashes every time when trying to open this file:
http://thepiratebay.se/torrent/4944942/ ... n_Xbox_ISO
Crash when trying to open XBOX iso
- crystalidea
- crystalidea
Re: Crash when trying to open XBOX iso
Confirmed. Salamander v2.54 and 3.02x86 both go out of memory and then ask for termination. Salamander v3.02x64 shows an error message, opens the ISO, but the contents seem to be a bit broken. IsoBuster shows different contents. Windows Explorer just says it's corrupted.
Size: 4 641 783 808 B
CRC32: 3DFFBFEA
MD5: 783ED003279C2A0866ABC7B91D8A62F3
CRC32: 3DFFBFEA
- salamander-v302x64-contents.png (23.49 KiB) Viewed 35083 times
- salamander-v302x64.png (4.95 KiB) Viewed 35083 times
- salamander-v254.png (10.01 KiB) Viewed 35083 times
Thank you, we will look at this problem.
Ether,
what does that mean? Does IsoBuster also indicate the image is corrupted? Can Windows Explorer actually mount/open any other XBox image? My Win5.2/6/7 doesn't seem capable of mounting even a regular ISO image.Ether wrote:IsoBuster shows different contents. Windows Explorer just says it's corrupted.
Windows 8 is able to mount ISO images. IsoBuster didn't indicate any corruption.
BTW Windows 7 is actually version 6.1.
Fixed for the next version of AS. There was a problem with scanning directories with too many entries. Requires testing with many Xbox diskimages for regression issues, because I can't believe Windows Explorer from the same company has problems parsing this particular image that was made already 5 years ago (BTW, the Creation Date shown by the F3 key was wrong as well, fixed as well).Ether wrote:Confirmed. Salamander v2.54 and 3.02x86 both go out of memory and then ask for termination. Salamander v3.02x64 shows an error message, opens the ISO, but the contents seem to be a bit broken. IsoBuster shows different contents. Windows Explorer just says it's corrupted.
BTW, IsoBuster lists only very few files in this image while the total number of files is 982. For example UltraISO lists all of them.
