Windows 8.1 update 1 - Skydrive/Onedrive link doesn't work
Posted: 05 May 2014, 19:15
by npaufler
I have Salamander 3.0 installed on a Windows 8.1 update 1 machine. In the drive selection dropdown box in Salamander, I see a link to 'Skydrive' but if I click it, it tells me that the c:\Users\myname\Skydrive folder does not exist.
My actual path is d:\Onedrive (i'd moved the folder using the Onedrive setting to change it's location)
Is there any way to manually update the path?
Re: Windows 8.1 update 1 - Skydrive/Onedrive link doesn't wo
Posted: 05 May 2014, 21:30
by Petr Solin
I will look at it and let you know. Probably next week.
Posted: 29 May 2014, 09:49
by blue.bear
Strange. Did you manage to check this problem?
__________________________________________
wniosek o dotacje unijne,
car lpg conversion,
weight loss methods,
bilety autokarowe,
krakow
Posted: 29 May 2014, 10:33
What Windows version do you use? x64 or x86?
blue.bear, can you reproduce this problem?
Posted: 30 May 2014, 09:51
by Petr Solin
It is fixed, sorry for delay. We get it from SHGetKnownFolderPath for FOLDERID_SkyDrive now, so I believe it will work forever this time.
Patch will be available in version 3.02 which will be released today.
