I have Salamander 3.0 installed on a Windows 8.1 update 1 machine. In the drive selection dropdown box in Salamander, I see a link to 'Skydrive' but if I click it, it tells me that the c:\Users\myname\Skydrive folder does not exist.
My actual path is d:\Onedrive (i'd moved the folder using the Onedrive setting to change it's location)
Is there any way to manually update the path?
Windows 8.1 update 1 - Skydrive/Onedrive link doesn't work
Re: Windows 8.1 update 1 - Skydrive/Onedrive link doesn't wo
I will look at it and let you know. Probably next week.
Strange. Did you manage to check this problem?
__________________________________________
wniosek o dotacje unijne, car lpg conversion, weight loss methods, bilety autokarowe, krakow
What Windows version do you use? x64 or x86?
blue.bear, can you reproduce this problem?
It is fixed, sorry for delay. We get it from SHGetKnownFolderPath for FOLDERID_SkyDrive now, so I believe it will work forever this time.
Patch will be available in version 3.02 which will be released today.
