Hi
I don't know if anyone is having the same problem as me but I can't use the clipboard in Salamander at all in my Windows 8.1 installation. I am using 3.0 beta 4 (x86). So when I try and copy text to paste into a file rename using F2 and then Control-V, nothing is pasted at all.
Please can anyone help ?
Regards
Robert.
Copy and Paste not working in Windows 8.1
Re: Copy and Paste not working in Windows 8.1
Does copypasting work in other applications? Is both copying and pasting broken in Salamander, or are you able to copy from Salamander to other application or paste from other application into Salamander?
rgasparotto
I can paste what I copy from Salamander (like the file name in an F2) into other applications. I can also paste from other apps into other apps. It is just Salamander. I can copy from Salamander though - I just can't paste into Salamander.
rgasparotto
Re-installed my copy of 2.54 and it works again - so it is the beta's fault
Help !
Help !
