PREVIEW: Altap Salamander SDK for .NET
manison
Post by manison »
With Altap Salamander Managed SDK you can develop Altap Salamander plugins with .NET Framework in any supported language (C#, Visual Basic, F#, etc.). Rather than full featured SDK this is proof of concept right now. If you are interested, download the SDK bellow, read the included documentation and try the examples. Post your comments and suggestions here.
Download Altap Salamander Managed SDK
knick
Re: PREVIEW: Altap Salamander SDK for .NET
Post by knick »
Manison,
please continue your work!!!! This is awsome! I'm looking forward for new / enhanced versions. I hope someday it will be possible to write a file system plugin (for SCP - so I can inally remove the 32 Bit Version of Salamander)....
Bye,
Michael
MartinS
Post by MartinS »
Thank you Manison.
darilek
Post by darilek »
great news :-) Please can You provide updated version for AS 3.0 (final version)?
-=:|MaD|:=-
manison
Post by manison »
Altap Salamander Managed SDK was updated for final version of Altap Salamander 3.0.
darilek
Post by darilek »
Thanks for this release.
Some suggestions for next release:
- allow register shortcut for menu item (or plugin?)
- ability to display popup menu like original user menu (F9) or Automation plugin does
Edit:
- shortcut could be assigned in plugin manager, this is sufficient for me
-=:|MaD|:=-
darilek
Post by darilek »
BUG: Setting path for panel (any of LeftPanel, RightPanel, SourcePanel or TargetPanel), i.e. this.Salamander.LeftPanel.Path = @"c:\temp"; does not work. Path is not changed.
-=:|MaD|:=-
manison
Post by manison »
Download updated Altap Salamander Managed SDK
Changes in this version:
  • New MenuItem.ShortcutKeys property
  • Setter for the Panel.Path property implemented
  • Compatible with Altap Salamander 3.01
