Beta4 can not unpack *.gz
Hi Salamander Team,
Salamander 3 ist unable to unzip *.gz files (create on Linux "gzip file.txt"), but Total Commander can, see Screenie.
But Salamander 2.5 on the same machine can.
Machine: "Salamander 3 beta4 x86" on "Windows 8.1 x64"
- Salamander 2.5 can unzip *.gz
- 2014.01.16_00006.png (20.47 KiB) Viewed 47982 times
- Unable to unzip *.gz
- 2014.01.16_00005.png (40.45 KiB) Viewed 47982 times
Regards, Axel
Tomas Kopal
Re: Beta4 can not unpack *.gz
You really can't extract the archive, or just the displayed size is wrong?
Can you, please, share with us the archive which fails to open? Or create one for us, which would be also failing, but without any sensitive data, if that's the case with the original archive.
Only size is wrong, my fault, sorry.
You need an example file furthermore?
Regards, Axel
Tomas Kopal
No problem, thanks for getting back to us.lexa wrote:> You really can't extract the archive, or just the displayed size is wrong?
Well, according to your screenshots it seems that the older version did show the size. If it is the same archive, it's a regression, and then yes, I would still like to have sample archive to debug.lexa wrote: You need an example file furthermore?
However, if it is a different archive, then it's most probably a "feature" of gzip format, where size information is optional and gzip archivers omit it very often, so we don't have anything to show in such case.
Hi Thomas,
Systems: GNU gzip 1.3.12 (x86 and x64) on older Linux OpenSuSE 11.2 + Debian 6
Yes, it's of course the same archive on all those screeshots, but for your tests I created a new (and anonymous) one for you with the same behaviour (TC 8 and Sal 2.5 shows the size, Sal 3b4 not).If it is the same archive, it's a regression, and then yes, I would still like to have sample archive to debug
# dd if=/dev/zero of=testfile.log bs=512 count=20480
# gzip testfile.log- Attachments
- testfile.log.gz
- a zipped bunch of zero's
- (9.98 KiB) Downloaded 1700 times
Regards, Axel
Tomas Kopal
Thanks a lot for the samples. Unfortunately, after I have traced the code execution to gzip listing, I just found a comment in the code explaining why the size was intentionally removed.
The reason is that not all archives contains the size, and there is no reliable way to find out if the size is there or not. And if this is not enough, second problem is that the size is 32-bit only, and it wraps for bigger gzipped files. Again, no way to tell if the number is correct or wrapped.
So, thinking that it's better to show nothing than to show nonsense, we removed it. Sorry for the confusion...
Well, 0 is not "nothing", and as you have seen, causes confusion. Couldn't you display nothing (a blank space) or something to denote, that the size is unknown (a question mark for instance)?Tomas Kopal wrote:So, thinking that it's better to show nothing than to show nonsense, we removed it. Sorry for the confusion...
Tomas Kopal wrote:The reason is that not all archives contains the size, and there is no reliable way to find out if the size is there or not. And if this is not enough, second problem is that the size is 32-bit only, and it wraps for bigger gzipped files. Again, no way to tell if the number is correct or wrapped.
The standard requires the size as a mandatory component. So I feel you shouldn't cater for gzip files with missing size in such a way.RFC 1952 wrote:A compliant compressor must produce files with correct ID1, ID2, CM, CRC32, and ISIZE, but may set all the other fields in the fixed-length part of the header to default values (255 for OS, 0 for all others).
Except for pathological cases (such as lexa's test case), and huge gz files, you should be able to quite reliably estimate the number of 4 GB junks you need to add to the 32-bit ISIZE value.
Tomas Kopal
Yes, that would be the best way, I agree. Unfortunately, plugin API is a bit limited in this regard at this moment, and enhancing it to be able to display something else than numbers in this column is non-trivial, and low on the todo-list. So for now, it's zero. Considering the fact that this is the first (or maybe second?) such request in all those years gzip is supported in salamander, it's probably not the most important thing to do, sorry.SvA wrote:Well, 0 is not "nothing", and as you have seen, causes confusion. Couldn't you display nothing (a blank space) or something to denote, that the size is unknown (a question mark for instance)?Tomas Kopal wrote:So, thinking that it's better to show nothing than to show nonsense, we removed it. Sorry for the confusion...
We have been there, we were displaying the size in prior versions. We have removed it because people were reporting wrong values. It's nice to have a standard, but it's useless if other programs do not follow it...SvA wrote:Tomas Kopal wrote:The reason is that not all archives contains the size, and there is no reliable way to find out if the size is there or not. And if this is not enough, second problem is that the size is 32-bit only, and it wraps for bigger gzipped files. Again, no way to tell if the number is correct or wrapped.The standard requires the size as a mandatory component. So I feel you shouldn't cater for gzip files with missing size in such a way.RFC 1952 wrote:A compliant compressor must produce files with correct ID1, ID2, CM, CRC32, and ISIZE, but may set all the other fields in the fixed-length part of the header to default values (255 for OS, 0 for all others).
Unless someone comes with a reliable way of telling whether the size is correct, we won't be changing the implementation there and back, sorry.
Hi Tomas,
I agree: This is not so high on priority, but it looks ... mmh ... strange if such a very nice + powerful tool like Salamander is not (or no more) able to determine the size of gzipped files. That's an open (not proprietary) and well documented format for (de-)compressing files. And thinking the next, when Salamander is going to unpack, how will it calculate the available diskspace for warnings...?
In Salamanders default configuration, the following filetypes are associated to the one-for-all "TAR" plugin: "tgz;tbz;taz;tar;gz;bz;bz2;z;rpm;cpio;deb"
So I miss the "tar.gz". How is it handled? It looks like same as ".gz". But why different results? ...see 2.)
Maybe a separate g[un]zip Plugin for gzipped files is the solution?
1.) Study of the gzip sources may help you:
2.) See my new screenshot below, how Salamander handles and shows *.tar.gz files in another way as *.gz. I think, there must be a way in your own code to do this.
So Tomas, I'll do my best so that should be my last try to confuse you with my .gz problem
Why not, I got two of itUnless someone comes with a reliable way of telling whether the size is correct...
me:/srv # gzip --list bigfile.txt.gz
compressed uncompressed ratio uncompressed_name
200774480 3217555456 93.8% bigfile.txt
There was no real reason to grumble in all those years. The gzip functionality was working almost very fine - for all users, but a fewConsidering the fact that this is the first (or maybe second?) such request in all those years ...
- another way to calculate .gz?
- 2014.01.29_00003.png (27.5 KiB) Viewed 47838 times
Regards, Axel
Tomas Kopal
Yes, gzip is open and documented format (I would probably leave out the "well" word here, I had studied the documentation quite hard, but it could be worselexa wrote:Hi Tomas,
No need to separate it.lexa wrote: In Salamanders default configuration, the following filetypes are associated to the one-for-all "TAR" plugin: "tgz;tbz;taz;tar;gz;bz;bz2;z;rpm;cpio;deb"
tar.gz is completely different case. That's a tar archive compressed with gzip. The information Salamander displays are taken from the tar archive, not from gzip. The same holds for tar.bz, tar.Z etc.
Not sure how this is handled, maybe gzip format got another format variantlexa wrote: 1.) Study of the gzip sources may help you:
me:/srv # gzip --list bigfile.txt.gz compressed uncompressed ratio uncompressed_name 200774480 3217555456 93.8% bigfile.txt
That's the only place mentioning the size. And from our experience, even this information is sometimes not present. And I am not even starting about gzip with multiple streams. To get a slightly better idea of the problem, try googling a bit, you may find e.g. http://stackoverflow.com/questions/9715 ... -gzip-file. In short, the only reliable way to find out the size of the uncompressed file is to decompress it. We were considering this option, but we decided that the time it takes to decompress the file is not worth the information (although e.g. for the tar.gz format you mentioned it is done, as there is no other way to list the contents).4 bytes uncompressed input size modulo 2^32
So, although I agree that the current behavior is not optimal, we think it is still the best. The only improvement we may do in the future is to remove the zero or remove the size column altogether. Sorry...
As I mentioned above, tar.gz is taking the information from different source, it's basically completely different archive.lexa wrote: 2.) See my new screenshot below, how Salamander handles and shows *.tar.gz files in another way as *.gz. I think, there must be a way in your own code to do this.
Well, if you find any usable information how to get the size reliably (by reliably, I mean it works in 100% cases, we are not interested in any heuristics which only mostly works), then feel free to come back and I will do my best to fix the problem. But at this time, it would be a change from one bad state to another, and that's not worth my time, sorry.lexa wrote: So Tomas, I'll do my best so that should be my last try to confuse you with my .gz problem
I'll chime in
Just had the occasion to come across some .gz files.
> Mozilla (SeaMonkey, Firefox,...), about:memory, Measure & save..., saves to .gz files
Next step was to do that again in a different version of FF.
Then to load the two reports with, Load and diff...
Doing so, I got, well essentially nothing.
(Two lines of text, I took to be headers, & nothing more, where I would have expected much more.)
Next step was to actually "look" at these .gz files.
So I "open" them & see "0" bytes, & I'm like, oh, no wonder my diff wasn't reporting anything! The generated file, that created the .gz, must have farted, so no actual content made it in there.
And then it dawned on me...
That thread in the Salamander forums. "0" bytes might be "expected".
F3, ah, there is data there. Guess what I just ran into!
F5, ah, there is some 20 MB of data there.
So yes, for a moment, seeing a "0" did throw me off.
Now knowing this, & having run into it this first time, I'll know for the next.
But seeing 0 did throw me off.
And if we can't get the "correct" number, perhaps an "N/A" (Not Applicable [& translation issues to go along with that]) or "-" or "?" or ...
