Please add options to force window states on windows opened from User Menu items.
For instance:
[x] Open Minimized
[ ] Open Normal
[ ] Open Maximized
I have a utility or two that work "in the background" and whose windows should open minimized. Currently can't do that in Salamander.
User Menu: Window state option (Min, Normal, Max)
Re: User Menu: Window state option (Min, Normal, Max)
This has not yet been integrated? I have the problem that the editor I set for text files (EmEditor) does not open maximized. It's annoying that I have to resize it everytime. When I open/close the editor not through Altap Salamander it remebers the state of the window and opens fine the next time. But with Altap Salamander it opens everytime in non-maximized state.
The position is remembered however. Thus I conclude the opening function for editors is set to non-maximized state if that is possible.
I use the demo/trial of Altap Salamander 2.52.
Solution:
SvA wrote:Till it's added you can create a link to your program, tweak it and then add this link to your user menu.
