"RMB drag&drop pop-up" - question
AbteriX
Post by AbteriX »
An older bad behaviour (IMHO) i reported already bevor months by mail is...
... if i right click and drag and drop an file to the other panel
i get an pop-up menu with the options
Move here
Copy here
Other...
Cancel
I want to create an link to that file... so i click "Other..."
Than (i think) a DLL is called and provide me "Create an Link" (in german words)
Question:
why is there this sub menu in this pop-up ?
Can't there be this "Create an Link" -item in the main pop-up too?
Like
Move here
Copy here
Create an Link
Other...
Cancel
Because i want to RMB-d&d and then just click on "Create an Link"
Other opinions ?
Or should i learn to use "Ctrl+C" / "Ctrl+S" ? :roll:
We know about this flaw and know how to solve it. Unfortunately, the fix is quite complicated (shell extenstion must be implemented), so it was postponed.
Thank you for reporting it.
Werner Gamper
Re: "RMB drag&drop pop-up" - question
Post by Werner Gamper »
AbteriX wrote: Move here
Copy here
Create an Link
Other...
Cancel
Other opinions ?
As a (faster) workaround, you could press the Alt-Key while you drag the file. It creates a Link.
HTH Werner
AbteriX
Post by AbteriX »
Werner Gamper wrote: you could press the Alt-Key while you drag the file. It creates a Link.
ALT-key ? Thank you, funktioniert prima ! Image
AbteriX
jis
Post by jis »
As a last resort try to read Windows help/manual... :lol:
BTW, Help and Support Center in Windows XP is really useful tool.
Windows keyboard shortcuts overview wrote:CTRL while dragging an item :arrow: Copy selected item.
CTRL+SHIFT while dragging an item :arrow: Create shortcut to selected item.
You can also "drag" a file by using right mouse button. On the target then just choose the action you want from the context menu.
AbteriX
Post by AbteriX »
Aha, "CTRL+SHIFT while dragging an item"
will do the same as "press ALT while dragging an item" , fascinating.
Thank you all for the tips. :lol:
AbteriX
