winscp can't login
jpermana
winscp can't login
Post by jpermana »
Hi
I tried to login using winscp plugin from Altap Salamander but failed. If I am login using normal winscp, successful.
Attached log from winscp plugin (NESA-test.log), and regular winscp (v07020@SE-UMTS-GLNE1@172.18.117.142.log).
Thanks for help.
Jpermana
v07020@SE-UMTS-GLNE1@172.18.117.142.zip
(2.71 KiB) Downloaded 995 times
NESA-test.zip
(1.56 KiB) Downloaded 1011 times
Martin Prikryl
Re: winscp can't login
Post by Martin Prikryl »
Thanks for your report. I've sent you PM.
Martin Prikryl
https://winscp.net/
jpermana
Post by jpermana »
Hi Martin,
I tried new version of Altap salamander 3, but winscp still not able to login. Any updated Winscp inside Altap Salamander ?
Thanks
Jpermana
jpermana
Post by jpermana »
Hi Martin/Peter,
The patches provided working good. I am able to login without error.
Thank you.
Jpermana
Martin Prikryl
Thanks for your feedback!
Martin Prikryl
https://winscp.net/
