Compare directories" doesn't work
Posted: 01 May 2006, 17:12
by mikey67
Since I installed the RC1 of SS the function "Compare directories" doesn't work. Nothing happens when I press the OK button. What's the catch? It worked until recently with the beta 11. :(
Re: Compare directories" doesn't work
Posted: 01 May 2006, 17:47
by jis
And what checkboxes do you have checked?
Posted: 01 May 2006, 20:04
by mikey67
jis wrote:And what checkboxes do you have checked?
Whatever is checked. It doesn't work anyway. :(
Posted: 01 May 2006, 20:11
by mikey67
Sorry, sorry!
I have found out that that this malfunction has got something to do with the unofficial translation (deutsch.slg). If I don't use it everything works fine. :x
