Compare directories" doesn't work
Since I installed the RC1 of SS the function "Compare directories" doesn't work. Nothing happens when I press the OK button. What's the catch? It worked until recently with the beta 11.
Re: Compare directories" doesn't work
And what checkboxes do you have checked?
Whatever is checked. It doesn't work anyway.jis wrote:And what checkboxes do you have checked?
