I am not familiar with programming. Nevertheless I am looking for examples or a description to use the Uderdefined Menu in Salamander. Is there anybody who can help me?
I just want to activate programms (e.g. winrar, winace or similar) via the usermenu. What is to fill in in the fields (GERMAN): Menüeinträge, Befehl, Argument, Programmverzeichnis. What is the meaninng of Untermenü, Trennzeichen, Ausführen in der Umgebung, Schliesse Umgebungsfenster, öffne Umgebungsfenster ?
I just need one oder two examples to understand the functionality. Thanks for helping.
Aberwizz
Help for Userdefined Menu
Re: Help for Userdefined Menu
You really should check the manual.
http://www.altap.cz/salamander/help/sal ... ize_usrmn/
Welcome.
To add a command, just click on the dotted row, or click the icon with a star that says Neu, enter the title for the menu item and then you can start filling out the fields and (un)checking the options.
Archivers (such as WinRAR, WinAce, 7-Zip...) have their own section in configuration (Packprogramme). I can give you an example how to configure an archiver, if you want.ABERWIZZ wrote:I just want to activate programms (e.g. winrar, winace or similar) via the usermenu.
This is self-explaining, it just says that the white box below it shows the menu contents.ABERWIZZ wrote:Menüeinträge
The path to the program to execute here.ABERWIZZ wrote:Befehl
The command line arguments for the program.ABERWIZZ wrote:Argument
(I have Ausführen in.)Where does the program start. This is not a widely used in Windows applications, but can be very important. Most of the time, the default $(FullPath) is the best.ABERWIZZ wrote:Programmverzeichnis
When this is checked, the menu item will become a submenu -- like a folder. You can put other user menu commands in it.ABERWIZZ wrote:Untermenü
(I have Trennlinie.) When this is checked, the menu item will become a separator -- a grey line, more or less. Separators don't do anything other than this.ABERWIZZ wrote:Trennzeichen
(I have In Kommandozeile ausführen.) This determines whether the program will be opened directly, or as a command in the command line interpreter (cmd.exe). If your Befehl is something like "dir" or "copy", you have to leave this checked and uncheck it for GUI applications.ABERWIZZ wrote:Ausführen in der Umgebung
(I have Kommandozeile öffnen.) If you choose to run the comand using the interpreter, the black window will appear by default and show any output the command will produce. If you uncheck this, the window will not appear.ABERWIZZ wrote:Öffne Umgebungsfenster
(I have Kommandozeile schließen.) If you allow the command window to appear, you can choose whether to have it closed automatically after the command finishes with this option.ABERWIZZ wrote:Schliesse Umgebungsfenster
- My menu.
- Menü.png (14.8 KiB) Viewed 8150 times
- My menu configuration.
- Konfiguration.png (34.6 KiB) Viewed 8150 times
