petee
Post
by petee » 25 Apr 2006, 20:20
Hi.
Bug or feature? In the window with the search-results it is only possible to sort the columns descending, ascending is not possible
I'm using beta 11.
petee
jis
Posts: 451 Joined: 27 Jan 2006, 23:14
Post
by jis » 25 Apr 2006, 20:52
I think that this is known shortcoming. We can expect Find improving in the next versions.
KNUT
Posts: 286 Joined: 12 Dec 2005, 09:57
Post
by KNUT » 26 Apr 2006, 10:32
petee wrote: Bug or feature? In the window with the search-results it is only possible to sort the columns descending, ascending is not possible
Already reported bug...
Kind regards, KNUT
