[Shift]+[Page Down] doesn't select the last entry in panels
Posted: 17 Apr 2006, 12:01
by Josip Tosic
when I work on laptops it's easier to use [Shift]+[Page Down] to select all content of a directory than to hunt down for [Num *] combo. The last file/directory in the panel is not selected, though.
On the other hand, [Shift]+[End] selects the last entry just fine but that usually requires another key on laptops so...
Posted: 18 Apr 2006, 21:58
Fixed, thank you for this bug report!
