when I work on laptops it's easier to use [Shift]+[Page Down] to select all content of a directory than to hunt down for [Num *] combo. The last file/directory in the panel is not selected, though.
On the other hand, [Shift]+[End] selects the last entry just fine but that usually requires another key on laptops so...
[Shift]+[Page Down] doesn't select the last entry in panels
- Josip Tosic
