Directory file list line string
Posted: 30 Aug 2012, 16:25
by Redhills
I'd like to get a list of file names in a directory in a column format. The file list is a few hundred long.
What line string do I use to put a RETURN after each name so it is in a column format?
Re: Directory file list line string
Posted: 31 Aug 2012, 01:53
$(FileName)$(CRLF)
Click the arrow right from the input field.
You can always hit the F1 in any dialog to get more information.
Posted: 31 Aug 2012, 14:11
by Redhills
Thank you!
I was close, but couldn't quite figure out the combination.
Posted: 01 Sep 2012, 08:32
From now it will be default value.
