Directory file list line string
Redhills
Post by Redhills »
I'd like to get a list of file names in a directory in a column format. The file list is a few hundred long.
What line string do I use to put a RETURN after each name so it is in a column format?
Re: Directory file list line string
$(FileName)$(CRLF)
Click the arrow right from the input field.
You can always hit the F1 in any dialog to get more information.
Redhills
Post by Redhills »
Thank you!
I was close, but couldn't quite figure out the combination.
From now it will be default value.
