Database Viewer prevents system shutdown
When a Database Viewer window is open and I try to shut down my system, shutdown comes to a halt. Windows displays a dialog box stating: 'The program cannot be terminated because it is waiting for input...'. Database Viewer (or SS) displays a message box stating: 'Some Database Viewer windows are opened. Do you want to close them? Yes / No'.
In my opinion, since nothing can be saved anyway, the question should be ommitted in case of a system shutdown. It should be configurable in case of a normal SS termination.
What is your opinion?
We know about this problem, it applies to all Servant Salamander viewers.
Btw, you should close (manually) Servant Salamander (and all other applications) before system shutdown.
Please look at http://forum.altap.cz/viewtopic.php?t=535 for details.
