Tree view, File-sizes ...
Moritz
Post by Moritz »
Hi ,
I love the Salamander and keep using it over the years. It has a lot of tools and features that I use on a regular basis.
But I (personally) still miss some features. Sometimes I need to track down the "space-hogs" of my disk i.e.which directories and/or files eat up the most space of my disk. For that task I prefer other tools e.g. DirectoryLister (or others of that type).
I would appreciate very much if you guys would implement some kind of tree view on one pane and the directory/file-sizes on the other pane. Switching the dir on the left should be reflected on the other pane ..... that would be great for me.
At least, give Salam a tree-view to see nesting levels of dirs, please!
Best regards!
DG
Re: Tree view, File-sizes ...
You should check the Disk Map plugin. MenuPlugins > DiskMap or just CTRL+Shift+D
