When copying some folders, I would like to ignore any subfolders called Archive (for example).
I tried the Files named checkbox (in Options) and typed *.*|Archive., but (as the name of the option might suggest) it doesn't consider folder names.
Why not? Can you please make it consider folder names as well?
