Make file list
gerdmuller13
Make file list
Post by gerdmuller13 »
Please, how can I create a list of directory (and sub-directory) files?
Thanks
Do you know about Commands > Make File List command?
Just select desired files and directories using the Insert key, then choose the Make File List command. Then choose output format...
Regarding sub-directories: this option is not available now.
We have this task on our to-do list.
Moving thread to General Discussion.
.me
Re: Make file list
Post by .me »
gerdmuller13 wrote:Please, how can I create a list of directory (and sub-directory) files?
Thanks
enter one of these commands in command line:
dir /on /s /b >_list.txt
or
dir /on /s >_list.txt
for more infos use this
dir /?
if you need this command very often you should create a button that does this job:
btw. you can also use the CRC/MD5 checksum plugin
(o.O) -(@.@)- (/o.O\) ,,,`Q´,,, {~.~} (^.^)
