Access to Directories History
I newer got warm with the List of Working Directories. It just looks like an unorganized mess to me. What I use rather frequently, though is the Alt+Left/Alt+Right shortcuts to go backward or forward in the "Directories History". This, however, can be a nuisance when you descend into a directory tree, back out not using the history, delete the directory tree and then use back in history. AS does not find the folder anymore and shows a message box telling you this, often several times in a row as you explored the now gone tree. A remedy was to use the little arrows beside the arrow icons on the top toolbar. Alas, I do not use the top toolbar, and if possible, I would like to avoid adding those icons to the Panel Toolbar, leaving more space for the path there.
Is that Directories History list available through the menu or a hotkey somewhere? Was it possible to substitute the arrow on the Panel Toolbar that brings up the List of Working Directories to some (possibly bidirectional) Directories History list?
Re: Access to Directories History
