My company changed to Windows 7 and now I can't install Salamander without admin right. Is there a way to install Salamander for example on drive D instead of Drive C, compared to a usb installation?
Regards
Michael
Installation Salamander without admin right
Re: Installation Salamander without admin right
Installation of AS without admin rights (as you know from Google Chrome) is not supported.
You can rename downloaded as254.exe to as254.7z, extract files and use Salamander without installation.
You will loose several features this way, for example proper uninstallation.
