Can I use the tool to move a list of files in a .csv or .txt
Hankh3
Post by Hankh3 »
Hello,
Can I use Salamander to move files using a .csv or .txt file? I have a multi layered folde rsource and need to move just specific files from source to destination in the same folder structure?
Re: Can I use the tool to move a list of files in a .csv or
No, such feature is not available. You can only store and restore a selection. But its limited to the actual folder and files.
I believe, that for your purpose a different tool would be useful - a synchronization software. Something like SyncToy.
