"Not enough storage is available to process this command."
I've been copying not-too-large amounts of data with AS 2.54 recently, and whenever I try to copy lots of files, I get "Error: (8) Not enough storage is available to process this command." repeatedly during the copying. The operation proceeds fine if I click "Retry", but how can I stop this error from showing up at all?
Re: "Not enough storage is available to process this command
Could you reproduce this problem?
What is your Windows version and disk file system (NTFS/FAT/some network disk,other...)?
Any time I copy sufficiently many files at once (not quite sure how many is sufficient) the error occurs.Jan Rysavy wrote:Could you reproduce this problem?
Please try to turn off your antivirus protection and reproduce the problem...
Please send me your Altap Salamander Product ID, you will find it in Help > About Altap Salamander.
Thank you.
Thank you.
Just ran into this myself
XP SP3, put in today's Windows Automatic Updates.
Other then "normal" stuff that I had open, I had (updated &) was running FreeFileSync, & I had NoVirusThanks running.
I had already copied a few files from server to networked computer.
Was in process of copying 8 files, 24 MB from server to networked when I got this "not enough storage" error.
The number in parens that I got was (1130), if that matters.
Closing FFS & NAVT, made no difference.
Restarted NAVT.
I can browse other networked computers, but not the one I had been writing too.
Windows Explorer gives the same error message, after timing out.
Checking IRPStackSize shows that I do not have that set on this computer.
Not sure why I ran into this all of a sudden?
Put in IRPStackSize, 0x15 (I hope that isn't default!), rebooted, & now when I try to access that computer (Win7, or Vista at the least it is), I get an "(58) The specified server cannot perform the requested operation" error.
I was able to go the other way from Win7 to server successfully.
Could just be that this particular Win7 computer needs a reboot, but I'm not in a position to do that at this time
Oh yeah. Also of late ... Adobe Flash & Adobe (Acrobat) Reader updates. (With the Reader, "Adobe ARM", whatever that is, does, set itself up in HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run. I've now disabled that.)
(And I think I'm just going to let things be until I know that computer can be rebooted, which may not be anytime soon.)
Restarted NAVT.
