Pasting a nest of folders short cut
domwhellams
Post by domwhellams »
Hi .. I am reasonably new to SS ... Part of my work flow requires me to copy and paste a set of pre organised folders into a specific location every time. Can you tell me if its possible to add a button maybe via the user menu to do this?
Many thanks in advance
Dominic
Re: Pasting a nest of folders short cut
Not that I can think of offhand.
(Maybe I'll think of something later?)
I have seen file managers that offer "virtual folders", where the VF would contain a set of links to various directories, so operations performed occur on those particular directories. (That may be like a Windows 7 "Library", perhaps?)
domwhellams
Thanks!! for now im just control dragging the nested folders into place which is just as quick really !! Win 7 64 bit
