Batch Rename-Plugin
Posted: 07 Oct 2011, 01:48
by Eric
Strange behavior:
I know in the Batch Rename Plugin, you have a live preview, when you start typing in the "Search for" textbox.
You should see the "New name" changing.
Doesn't work for me. Not sure if it's never worked, or suddenly stoppped (new Win7 64 Bit installation).
On other Win7 64bit it's working.
What could prevent the "live updating"?
Thanks
Eric
Re: Batch Rename-Plugin
Posted: 07 Oct 2011, 05:36
by therube
'Whole words' option checked (& you're not entering "whole words") would be my first guess.
Otherwise, Case sensitive, & your original names are all lower case, & you're typing in CAPS ...
Posted: 07 Oct 2011, 12:23
by Eric
Thanks, but it should be renamed.
Because when I pressed 'Rename', it was renamed.
BTW:
The behavior was gone the next day.
So one mystery solved :cry:
