Batch Rename-Plugin
Eric
Batch Rename-Plugin
Post by Eric »
Strange behavior:
I know in the Batch Rename Plugin, you have a live preview, when you start typing in the "Search for" textbox.
You should see the "New name" changing.
Doesn't work for me. Not sure if it's never worked, or suddenly stoppped (new Win7 64 Bit installation).
On other Win7 64bit it's working.
What could prevent the "live updating"?
Thanks
Eric
Re: Batch Rename-Plugin
'Whole words' option checked (& you're not entering "whole words") would be my first guess.
Otherwise, Case sensitive, & your original names are all lower case, & you're typing in CAPS ...
Eric
Post by Eric »
Thanks, but it should be renamed.
Because when I pressed 'Rename', it was renamed.
BTW:
The behavior was gone the next day.
So one mystery solved :cry:
