Adding a new file format to PictView plugin
Grzegorz
Post by Grzegorz »
Is it possible to add support for new graphic format to PictView plugin? I.e. Is there an interface in PictView that would allow to to that?
I had designed my own graphic format few years ago and I would like Atlap Salamander to be able to display thumbnails for that files. I could write a simple dll that exports one function which would read my own file format and convert it to a 32bit DIB or something like that for the PicView plugin.
But this would require a plugin interface for a plugin, so I wonder if there is such an interface within PictView plugin.
Re: Adding a new file format to PictView plugin
It will be easier to add specific DLL with proper interface.
I also ask if the autor of PictView plugin consider more *opened* interface like load all plugins from for example XnView if path to installation is set.
