Copying from one panel to another stopped working
jadag
Post by jadag »
I have been using Salamander for years.
Suddenly last week when I tried copying a file from one direcory (in panel 1) to another directory (in panel 2), nothing happens!
Dragging does work in other programmes (e.g. Q-Dir) when copying as above.
I can't seem to see anything in the configuration setting about this. Can anyone please point me in the right direction to solve this?
Vista Home
Salamander 2.53
Thanks - Tony
If you know you're going to lose - lose quickly!
Re: Copying from one panel to another stopped working
What method are you using to copy files (F5, dragging)? Does the other method work?
What specifically is the problem - a Copy/Move dialog doesn't appear when it should?
jadag
Post by jadag »
I usually right-click on the source file in panel 1 and drag it to the destination folder in panel 2 and release the right mouse button. Salamander used to then show a menu asking me if I wanted to;
- Move the file
- Copy the file
- Other
Now if I right-click on the source file and drag it to the destination folder and release the right mouse button nothing happens at all. :(
If I LEFT-click the source file and drag it to the destination folder (and release the left mouse button) it does MOVE the file from the source to the destination! :D
If I select the source file and right-click and release, a windows context menu opens and if I select "copy to folder" it will open a "browse" window and then I have to click through the various options till I get the destination folder and click "Okay". It will then copy the file BUT this is really a schlepp compared to just "dragging".
Hope this is clear
Regards - Tony
If you perform the same procedure using two Windows Explorer windows, do you get the expected actions?
Perhaps a conflict that ShellExView - Shell Extensions Manager may help pinpoint?
jadag
Post by jadag »
As I regularly backup my registry using "Registrar Registry Manager" (freeware) I restored a previous backup and all is well again.
So the problem must be in the registry and not with Salamander.
In any event, thank you for your support.
Regards,
Tony from a sunny South Africa
"Stop The Slaughter - 300 Rhinos killed for theit horns this year!!"
