Recovering files over 4GB
Posted: 26 Apr 2011, 00:57
by rgraff
How can I recover files over 4GB? I have several large (~8GB) DVD images that I'd like to recover. All show file size of 0 KB. Other deleted DVD images up to 3.99GB show up.
Rob
Re: Recovering files over 4GB
Posted: 26 Apr 2011, 18:03
Salamanders recovery plugin has a 32bit limit (4GB). You might try another tool - Recuva for example. But remember that you MUST NOT write to the drive, else the content gets overwritten. This means if the files are on the system partitions, you MUST do it from a different computer, else you loose the files.
Posted: 27 Apr 2011, 07:31
We must look into this problem. Undelete plugin has no 4GB file size limit.
Posted: 27 Apr 2011, 11:31
Then it might be that the file is already unrecoverable, because it was partially overwritten.
Posted: 27 Apr 2011, 21:24
by Jan Patera
rgraff wrote:How can I recover files over 4GB? I have several large (~8GB) DVD images that I'd like to recover. All show file size of 0 KB. Other deleted DVD images up to 3.99GB show up.
Confirmed: I just deleted a 5.5GB file on a non-system NTFS disk. Undelete plugin in AS 2.54 launched immediatelly claims the zero size.
